aftermarket cam on a 12v before and after?
Old 07-25-2008, 11:15 PM
kawi600's Avatar
Anyone got experience with adding a cam to a 400hp-ish 12v? Im curious as to what it did for your power, spool time and smoke levels.
Ive got a choice between a cam and a fuel pump and Im thinking the cam is the best mod to do now since it should clear up the smoke I have before I add more.
Old 07-26-2008, 07:02 AM
ratsun's Avatar
What pump you going to put on?
The 913 pump was probably one of the sweetest upgrades I've done.
The cam is a tough call as to if it was worth the work but I did notice a few gains in spool up and egts, however it really depends on what you need the truck for and where you want to go with it. I did the cam swap while the truck was around 350-400hp but knew I would be going higher and I did a little trading with Don for it so.....
steelblitzkrieg
Off Road / 4x4
01-05-2013 07:53 PM
AH64ID
01-18-2009 04:59 PM
desertchecker
02-18-2008 09:32 AM
jwb600
13
02-03-2008 10:53 PM
Quick Reply: aftermarket cam on a 12v before and after?
