aftermarket 4" exhaust
Now Im kinda confused. Ive been looking at different companies 4" systems, and most list for 94-97 and another for 98-02 for the 24 valve. But after looking at Ebay, theres one listed for 94-02. Is there a difference? Summit has one listed for the 98-02 for about 300. Since I have a gift certificate there,I like to know if anyone has put one on a 12 valve. Anyone???
Well, I called Summit to ask about the exhaust. The sales guy said it would work on 94-98 if you have a cat. So I asked him if I dont, why wouldnt it work. Maybe they only give enough pipe to incorperate the convertor, but that doesnt make a whole lot of sence either. Anyone out there put one on from Summit, any year?
The 94-97 have a different hanger for the tailpipe. Other than that the systems will bolt up the same.
The reason some only want to sell kits for the 98+ is because on the pre-98.5 trucks you would be removing the CAT to install the complete system and some don't want to recommend this.
Next question...
How is the exhaust system on the ex. cab/ std. bed different than the std. cab long bed? I think Magnaflow only shows the system being offered for the ex. cab (which I don't have). I'm assuming the "std. bed" is the 6' bed. If not then it sounds like the system may be a couple of feet longer than I'm need, but that's easy enough to shorten.
Thanks for the info guys!
Originally posted by Rhino
The only difference is length. If it is too long it would be easy enough to trim a piece and make it shorter.
Thank you.
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
Hemlockusa
01-28-2006 07:07 AM
Original Junior
11-19-2003 10:13 AM
