AFC Issue
Old 12-04-2006, 07:40 AM
Mopar440_6's Avatar
AFC Issue
Well now that I know my transmission isn't on its death bed (WOOT!) I can finally turn the fuel up some without fear of grenading a bad trans. The problem is that I can't seem to get the starwheel plug out of the AFC housing. I used an 8mm allen wrench and put some serious force on it. I stopped trying to turn it when I felt it starting to slip but the plug wasn't turning. So now the socket in the plug is wallowed out slightly. Is there something else I can try to get the plug out? Or should I just go ahead and get a new AFC housing and change the fuel plate while I'm at it?
Old 12-04-2006, 07:13 PM
dslpower's Avatar
Take a small chisel and tap around the edge to break the seal. Then it should unscrew.
Old 12-04-2006, 07:47 PM
Mopar440_6's Avatar
Woo-Hoo! Thanks DslPower! The chisel worked like a charm. The wheel was already about 3/4s of the way front (thats starting from the back of the opening), so I only turned it up about 3 or 4 clicks but WOW! She runs like a whole different truck! I can't wait to turn it up some more and put a 10 plate in but from what I have gathered on here I MUST do gauges first...
dan123dbl
02-13-2015 05:47 PM
freds89
03-31-2010 07:15 PM
royta
02-15-2005 10:15 PM
DDysput
05-05-2004 07:44 AM
Quick Reply: AFC Issue
