adrenaline?
Old 07-25-2008, 03:17 PM
nofear's Avatar
adrenaline?
i was thinking about getting the adrenaline, but since i already have gauges do yall think i should get the pulse also? thanks
Old 07-25-2008, 11:02 PM
hink's Avatar
I would get the Pulse. There are tons of different features that you can use with the Pulse that you cannot use with the control pod that comes with the Adrenaline.
Old 07-26-2008, 10:01 AM
RowJ's Avatar
Definately, if you like bells & whistles in the form of multiple readouts, EGT defueling, Turbo Timers, personalized power curves, etc. ....and/or plan on adding HP in future. I don't see many selling in the future w/o the Pulse.
RJ
Old 07-26-2008, 05:31 PM
Kenworth's Avatar
I can't seem to find on a search or on Quadzilla website but what are the power/torque increments for each of the 10 levels?
Old 07-26-2008, 11:37 PM
hink's Avatar
There are no HP/TQ ratings for each level, atl least none that I'm aware of.
The first level would be 30-35hp, level 2 would be 60-65hp and levels 3 and higher is fueling through the wire tap, but I have never seen any ratings for those levels.
Old 07-27-2008, 06:52 AM
mahdey's Avatar
I have an adrenaline. 1 is better than stock two is somewhat more noticable, 3 is like a bat outta hell, 4 and higher..wow. I need a bigger turbo to burn off that extra fuel.
Old 07-27-2008, 01:42 PM
scottsjeeprolet's Avatar
PL1 is timing only, PL2 is timing + can bus fueling and PL 3 & up is timing + wire tap fueling. I usually run PL5 on the 1000a tune.
Old 08-01-2008, 05:07 PM
nofear's Avatar
hey guys thanks for the imput. more than likely i will go with the pulse.
bnold
2509
07-24-2008 10:57 PM
qzilla
218
01-30-2008 08:20 AM
sway825
12-14-2007 07:57 PM
tex23455
11-21-2007 04:38 AM
vzdude
10-17-2007 04:32 PM
Quick Reply: adrenaline?
