Adrenaline Problems
Adrenaline Problems
I lost the cable that connects my computer to the adrenaline and I have bought 3 other cables but when I connect any of them the program cannot find the module. The compute has Windows Vista.
Is this the first time you've hooked up your adrenaline to your computer?
Some Vista machines have problems and won't work with the adrenaline. Is it a 64bit or 32bit processor?
The 64bit might be your problem. I've talked to Jeremy about this before and he said that the 32bit processors don't have a problem, but a lot if not all of the 64 bits do.
As long as the other one is a 32bit then yes. I've noticed that even though the 32bit Vista platforms say that the drivers for the program were not successfully installed that the program still works. XP is a lot easier to use when you're doing the setup, but if you know what you're doing then the 32bit Vista should work too.
isu elvi
06-20-2008 02:39 PM
ramcummins
18
06-07-2008 12:35 PM
