Adjusting valves on a 06
Old 08-12-2008, 05:34 PM
12valve's Avatar
After putting on a oringed head, a 2nd gen headgasket, i think i should adjust the valves,
What are the valve lash specs for a 2006 CR with say around 750 HP?
I lost the sticker on the valve cover...
Any tips are appreciated too.
Old 08-12-2008, 05:44 PM
wap
wap's Avatar
I THINK on my 05 its .020 and .010, but I would need to double check, and while I would also THINK the 06 is the same I am not 100%.
Jame's Avatar
factory spec with coolant less than 140F is .010 intake .026 exhaust
Old 08-12-2008, 05:52 PM
12valve's Avatar
thanks Jame
Old 08-12-2008, 07:09 PM
dieselfan's Avatar
why a 2nd gen HG? is it b/c of o-rings?
Old 08-12-2008, 07:58 PM
82NDSNPR's Avatar
the hp dont matter and the valve lash is found on the side of the valve cover thats where i found mine
Old 08-12-2008, 08:03 PM
Howling's Avatar
Yes the 2nd gen gasket is usually water jetted for the size of the oring.
Old 08-12-2008, 08:08 PM
dieselfan's Avatar
thank you
Old 08-15-2008, 10:43 AM
12valve's Avatar
I dont know what you mean with that right there...
can you clear that up for me?
BTW i just used The 2nd gen HG the way it came... hope i did the right thing...
marine4life
03-11-2006 08:36 PM
robox
08-16-2005 07:27 PM
CrewCabCummins
01-03-2005 04:29 PM
Denis
04-19-2004 12:32 PM
Puke
06-23-2003 01:06 PM
Quick Reply: Adjusting valves on a 06
