Adjust O/D shift?
Old 08-21-2008, 06:27 PM
kc8ksg's Avatar
Adjust O/D shift?
I was curious if there was a way to make my truck shift into O/D sooner, I have adjusted the T.V. cable and got 1,2,3 like I want it but O/D just holds out to long for my set up and I need to back off the throttle to get it to go in. Any suggestions?
Chris
Old 08-21-2008, 07:14 PM
RickCJ's Avatar
OD and lock up are electrically controlled. around 45-50 mph. Shouldn't be in od locked till 2000 rpm or better.
Keep the trans pump spinning 2000 or better and it will give a long life.
Old 08-24-2008, 12:18 PM
kc8ksg's Avatar
The o/d is fine just cruising and doesn't go in sooner than 40, but my questions is about at WOT it doesn't shift until around 3200 rpm and with my setup that is a little later than I would like, around 2800 at WOT would be more what I need.
Chris
Old 08-24-2008, 06:28 PM
RickCJ's Avatar
Chris
WOT shift at redline is perfect!
dzl_damon
08-03-2020 11:18 AM
simplysmn
10-26-2012 01:33 PM
2500CTD
10-10-2006 09:12 PM
CASMOKIN
Competition / Pulls / OffRoad
12-30-2005 01:28 PM
MoparRiggan
07-29-2005 12:02 PM
Quick Reply: Adjust O/D shift?
