Adding extra overload springs?
Old Oct 27, 2006 | 03:55 PM
Wesjr55's Avatar
Has anyone ever added extra overload springs to the rear of their truck? Not air or timbrens; just regular leaf springs.
Old Oct 27, 2006 | 06:11 PM
greasemonki's Avatar
On an old gasser w250 i put a set of custom overloads on. Are you talking about a second set of overloads? The overloads on this truck consisted of a rear leaf pack from a different truck. I mounted them with a block over the exsisting pack and then made brackets on the frame. They hold the road sander fully loaded without a problem.
Old Oct 31, 2006 | 03:15 PM
DanTana's Avatar
Rear leafs added
Please check out my site for my 2004.5 .. Half way down the page are pictures.
Old Oct 31, 2006 | 04:24 PM
durasmack's Avatar
I drove one that had extra leaves on it but were not setup as overloads... they were setup as all active springs. 13 leaves in the pack and ill tell you that it felt like it had a rigid suspension....
I have seen it done as extra overloads too. Either way it can be done but ride quality will change based on the way its set up.
Old Nov 3, 2006 | 06:45 AM
DuaneWKKC's Avatar
yes, to a 2002 2500 with camper package. The springs that come on the trucks are (sp?) parabolic, meaning VERY expensive to add to, so I removed the factory overload and added a 5k lb pack. Problem is they dont engage quick enough for me. With camper on truck, only the back of the pack is hard engaged. Really need to add about a 3/8" spacer under the overload pack. If I had to do it again, would have looked for overloads off of a 1 ton in junkyard. Older ones had two leafs not the singles.
good luck,
DuaneW.
Old Nov 3, 2006 | 06:50 AM
Pike's Avatar
I put Duratough overload springs on mine. There are 6 extra leafs per side, and work well for me. No drilling, just bolt on. You can adjust when the springs hit the stops too. I think they are heavier than the stock springs. I like them a lot. There is a pic or two in my gallery.
Old Nov 3, 2006 | 02:13 PM
Jerry Lancaster's Avatar
Smile
I had a 1996 1-ton dually, pulling a 34-foot Alpenlite 5th Wheel. It squatted it to where my mud flaps would touch the gound. I added one leaf on each rear springs, and it lifted the truck up just right. The ride was a little stiffer, but not bad.
qwest
May 18, 2006 09:46 AM
DuaneWKKC
Jan 28, 2005 06:11 PM
M0J0
17
Jan 22, 2005 07:42 PM
ckennedy
Nov 29, 2004 08:37 PM
