Added More pics..
Added More pics..
I've added some more pics here:
http://www.turbodieselregister.com/u...&albumid=16437
The crank wasn't too far out of balance but the rods were bad. #4 con rods was 32 grams heavier than the lightest rod(#3) the others where 18 to 24 grams heavy.
Also have pics of reciever groove in block to match the head o-ring and another o-ring out side the reciver groove in the block.
Also came up with a great thermo coating that I coated my ATS manifold with as well as the exhaust ports in the head.
Re: Added More pics..
Originally posted by drawson
The cranks wasn't too far out of balance but the rods where bad. #4 con rods was 32 grams heavier than the lightest rod(#3) the others where 18 to 24 grams heavy.
brandon.
They are the factory rods.
In the one pic you can see the tops that where ground down and also there is material removed from the bottom weight block on the rods.
DTR Founder
http://www.turbodieselregister.com/...?&albumid=16437
Mighty Goat
01-31-2008 11:20 AM
98ramtough
07-03-2007 01:16 PM
dieselminded
09-18-2004 11:14 AM
