Added CFM+ & Heater Deleter= Less Boost???
Old 02-28-2008, 09:47 AM
JIT
JIT's Avatar
I just added the CFM+ intake and Winspeed Heater Grid Delete spacer and lost about 3psi peak Boost? Is this because there is less restriction in flow meaning lower drive pressures? I checked for boost leaks and didnt find anything unusual. Is this normal?
Old 02-28-2008, 09:50 AM
DTR's 'Go to Guy'
vzdude's Avatar
Very possible! Boost is just a measure of pressure - and pressure = resistance. By removing some of the resistance, you lowered the pressure. However!......I'm sure you increased volume!
Old 02-28-2008, 09:59 AM
CamperAndy's Avatar
The problem is the boost pressure is measured down stream of the air horn and grid heater. So the loss of up stream restriction should mean more boost pressure at the manifold (where the boost is measured).
A really good test for those that are so inclined would be to install a second boost gauge at the outlet of the inner cooler. There they will see a major drop in boost pressure with a heater delete.
Old 02-28-2008, 10:09 AM
JIT
JIT's Avatar
Thats what I am thinking. Throttle response has increased and the turbo is really singing now. I'm happy with the components I just didnt know where the other 3psi went? Where does the stock system Map sensor measure boost Pressure?
Old 02-28-2008, 11:52 AM
DTR's 'Go to Guy'
vzdude's Avatar
In the intake manifold.
Old 02-28-2008, 03:46 PM
JIT
JIT's Avatar
OK so thats true Boost Pressure then... not like Boost measured at the turbo!
Old 02-28-2008, 05:56 PM
94 12valve's Avatar
The same thing happened to me when I installed the banks twin ram (should have gone with something else but I got it cheep) on my 12 valve i lost 4 psi with my stock charger but my egt's droped and my mpg's went up a little and the turbo really does sing now
Old 02-28-2008, 08:23 PM
98.5Hotrod's Avatar
Thats a good thing be Happy.
Old 02-29-2008, 12:21 AM
94 12valve's Avatar
trust me im very happy with it
Old 02-29-2008, 07:31 PM
Ronco95's Avatar
I agree with the explanation for the loss of boost. It is related to restriction. If you installed a cam, you would also see a loss of boost because the intake valves would open longer and flow more air and exhibit less restriction.
Ronnie
Old 03-27-2008, 09:38 PM
CL2000's Avatar
I know between my heater grid delete and ats manifold I lost boost when messured at the intake. I think that Adam gained 2 or 3 psi in the head after his install.
deerslayer1979
11-11-2008 08:01 AM
jmccart
07-17-2008 10:05 AM
js091899
03-16-2008 07:28 PM
RonP
04-02-2007 12:25 PM
Quick Reply: Added CFM+ & Heater Deleter= Less Boost???
