Acceptable oil pressure range
Old 06-22-2007, 11:48 PM
Cowboy_Customs's Avatar
Whats the acceptable oil pressure range for us? A bud of mine is seelin 10PSI at idle, 18 at 750. Need a new oil pump??
Old 06-23-2007, 01:20 AM
Chrisreyn's Avatar
From another site: engine specs, 89-91 engines
Oil Flow Rate :
Minimum Oil Pressure @ Idle: 10 psi
Minimum Oil Pressure @ Rated: 30 psi
Regulated Oil Pressure: 65 psi
Oil Filter Bypass Diff. Pressure: 20 psi
Old 06-23-2007, 07:18 AM
Hey, thanks for the PM n the link to Fritz's. I should have known to check there.
Old 06-23-2007, 04:10 PM
Sounds like he's just barely OK. You can pull the pump out and check the clearances, if they are good it's time for bearings.
Old 06-23-2007, 10:58 PM
Micaiahfied's Avatar
you said 10psi at idle and 18 at 750... what is his idle speed? if idle is around 800 or so he should be fine, unless i am reading it way wrong...
Old 06-24-2007, 07:14 AM
Im not sure what his idle speed is set to. Hes got a 90 D-350 dually, 727, 3.07 rear ratio truck. He said he was going to bump the idle up tp gain some PSI. I'll let him know when I talk to him later.
How do u check the tolerances on the oil pump/bearings? I'll do a search, but I havent ever seen it in the past year Ive been here, so this outta take a while! lol
Old 06-24-2007, 07:22 AM
gomerpile's Avatar
is the factory gauge a good way to diagnose a problem, or should i get a mech gauge to really check it.
Old 06-24-2007, 07:24 AM
timb's Avatar
It's allways a good idea to check your oil preassure with a mechanical guage.
Old 06-24-2007, 09:27 AM
You have to pull the oil pump (behind the timing cover) and check the clearance between the rotors and also the thickness of the rotors vs. the depth of the housing.
If you are going to check bearings you might as well roll in new ones while you have the pan off.
Old 06-24-2007, 02:42 PM
pred's Avatar
I just installed an oil press gauge
330 K miles
cold
40 idle
80 2k rpm
Really hot on a hot day with ac on and a 550 rpm idle
20 idle
45 2k rpm
What oil are you running? That can have alot to do with oil pressurre!
Peter.
Old 06-24-2007, 05:52 PM
gomerpile's Avatar
what is the threads for the oil pressure sending unit, im just gonna get a mech one and just plug it into the stock hole hopefully.
Old 06-24-2007, 07:32 PM
1/8" npt, standard pressure gauge stuff.
Old 06-24-2007, 09:58 PM
pred's Avatar
You can also plug it into the top of the oil filter housing, There is a little plug there waiting for you.
Old 06-25-2007, 07:35 AM
gomerpile's Avatar
well say im just trying to check it once, could i use a boost gauge and plug it into the oil pressure place, then just put it back into the manifold
Old 06-25-2007, 10:49 AM
gomerpile's Avatar
alright i just hooked up an old crappy PSI gauge to the before filter plut and it showed around 60 psi at idle and 80 psi at about 14-1500 rpms, does this sound right or like i have a screwed up gauge
Quick Reply: Acceptable oil pressure range
