AC problem 04.5 3500
Old 08-22-2011, 09:55 AM
Rottweiler's Avatar
My AC works on the driver side but not on the pass side, It blows air out the vents but it is not cold at all. Is there a seperate door that directs air past the evaporator for that side?
Old 08-22-2011, 10:07 AM
jhenson's Avatar
Sounds like a classic symptom of low charge.
Old 08-22-2011, 12:37 PM
ssandlin's Avatar
I'll second this one. And if that's the case, it means you have a leak somewhere.
Old 08-22-2011, 01:12 PM
Rottweiler's Avatar
with it cold on my side did not think it was low charge. I will have it checked for leaks.
Old 08-23-2011, 08:46 AM
jhenson's Avatar
Including mine, I've seen 4 Rams of different year models (03-07) that had a leaking Schrader Valve in the dryer. Tried changing it out and even tightening it but to no avail. Replaced dryer and recharged and all was well.
Just my .02
Old 08-23-2011, 12:09 PM
gcssr's Avatar
Before tearing a/c apart, try removing glove comp. and checking the recirc door. They are cheaply made and crack/ break causing poor air flow. If bad get the Heatertreater,replacment door,I speak from experience. Good luck
Old 08-23-2011, 12:29 PM
Spooler's Avatar
Just my .02
No schrader valves in or on our dryers.
Old 08-23-2011, 03:19 PM
Super Dave's Avatar
Mine was the same way for years, I just didn't notice it until my new wife mentioned it. 1lb of 134 fixed it right up, and its been working fine for 3 months now. It seems Dodge may have shorted our trucks on the 134. Put some gauges on it and I bet it reads low. Adding 134 is cheap and easy to do, I would start there. If it fixes the problem, but then leaks out, only then I would bother to look into it.
Old 08-23-2011, 03:48 PM
jhenson's Avatar
My bad Spooler....it's on the cold line connecting to the dryer.
Old 08-26-2011, 01:47 PM
Rottweiler's Avatar
Put in just over 1lb of 134 and that fixed it! will see how long it last and go from there.
Thanks for all the help
Tree DR
12-01-2008 07:14 PM
dragginlx
15
03-09-2007 11:32 AM
ptgarcia
09-12-2006 06:04 PM
tomasin13
10-09-2003 09:56 PM
OchelataBillybob
05-19-2003 10:56 AM
Quick Reply: AC problem 04.5 3500
