Abs light on, speedometer works fine
Old 11-24-2006, 08:20 AM
Bigdenny's Avatar
Lights on but speedometer ok. Abs lights on all the time. Has anybody had wiring issues with the rear abs?
Old 11-24-2006, 08:40 AM
RATTLINRAM's Avatar
Hey Bigdenny,
It might help for the members to have a little more info on your truck which you can supply in your signature.
You didn't mention if the red BRAKE light was lit up also. You can use the SEARCH function to help you find other possible threads containing helpful info too.
Here is one such post of mine with a little info that I came across when my rear wheel speed sensor went bad and caused the ABS/BRAKE lights to stay on. ABS thread
Hope you find your problem.
13ALPHA
24
05-04-2012 01:15 PM
Captum
13
05-01-2012 01:04 PM
jdddually
06-16-2011 09:18 PM
Rogers954
20
01-27-2011 07:39 PM
Bigdenny
19
02-24-2007 07:08 AM
Quick Reply: Abs light on, speedometer works fine
