ABS light and The cool-down timer
Old 11-09-2003, 05:31 PM
silverram323's Avatar
Do you guys have any problems with the ABS and brake light coming on right after you hit the start button on you timer? I do, and i set a code 0500 no vehicle speed sensor signal. I talked to Howard and he said hasn't heard of that problem. Well i did a little digging around in the shop manual and decided to put a jumper wire on fuse #3 (ABS and AWAL) So i have a jumper wire on #9 (engine) to #3 (ABS) so when the timer is on i have power to the ABS also. No lights and no codes works great. Let me now if it works for you too.. here is a pic take a look...
Kevin
Old 11-10-2003, 09:18 AM
y-knot's Avatar
Re:ABS light and The cool-down timer
It will lite my ABS warning light, but no codes.
06RAMCTD
11-06-2009 11:35 AM
mr T
02-24-2007 06:42 AM
TripleBquad
13
11-20-2006 02:59 PM
ckennedy
11-23-2004 12:46 AM
Quick Reply: ABS light and The cool-down timer
