ABS light and Brake Light and spedo
Old 11-23-2008, 09:20 PM
peak07's Avatar
hey guys, this is my first post here, my friend told me to check the site out, i have a 98.5 24 valve with a five speed, the problem i am having is that when i was driving this afternoon the abs and brake light came on, i searched the posts here and found some info on a sensor on the top of the rear end. I took that electrical connection appart, cleaned it with cleaner, checked wires coming in and then re-set the computer. none of these things helped my problem, i am also having a problem with the spedo not working for the first 25 mph or so but then it kicks in and does just fine..............any help here would be very much appreciated.........i recently added lucas oil stablizer to the rear end and motor but don't think that the oil stablizer should have anything to do with the problem..........please help me out here, thanks
Old 11-23-2008, 11:22 PM
cody_d's Avatar
it's that sensor that you read about, it's about $40 and takes about 10 to 15 minutes to change,(mine went out over the summer, same things happened) the lights and speedo are both connected to this. Its the ABS/ Speed sensor.
Old 11-24-2008, 10:07 AM
CoastalDav's Avatar
Same thing happened here. So, sounds like a ABS/Speed Sensor.
Dave
Old 11-25-2008, 08:01 AM
peak07's Avatar
thanks for the advice, i took the sensor out, and cleaned it off i thought the metal fragments that float around in a rear end could have messed with the sensor, but that didn't work the lights are still on and speedo does not work yet, i will try to buy another one today, if this does not work what is the next logical step for the problem
Old 11-25-2008, 08:14 PM
peak07's Avatar
ok so i just changed the sensor and it works great now, thanks for the advice cody d
Old 11-27-2008, 11:42 PM
cody_d's Avatar
your welcome. happy holidays.
Old 11-30-2008, 11:02 AM
fschiola's Avatar
I see you got your problem straightened out. Just to answer your question, the next step would have been to replace your stoplight switch. It has circuits to control the ABS, cruise control cut out and of course, brake lights.
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
mr T
02-24-2007 06:42 AM
dsldan
10-24-2006 06:02 AM
Quick Reply: ABS light and Brake Light and spedo
