ABS light on after RESCUING Z71
Old 12-17-2003, 10:42 PM
dodgediesel4x4's Avatar
Ok, listen to this. The other day, i had to pull my buds z71 outta some mud. We hooked up and i had to gently yank him out. Had to yank harder than i originally planned. Anyway, i got him out and on the drive home, my ABS light came on and the BRAKE light stayed on, continuously. I pulled over and double checked that the parking brake wasnt engaged. When i got home, i killed the engine, pumped the break pedal 3 times, then cranked her back up. Both lights were still on, and the parking break wasnt engaged. My bud called me up a few minutes later and said that his ABS light came on his way home, but went off before he got back.
The next morning, i started her and both lights were acting normal again. Any ideas what might have caused this, esp. in 2 different trucks??
Hunter
Old 12-17-2003, 11:29 PM
phox_mulder's Avatar
Re:ABS light on after RESCUING Z71
If you spun your tires a lot, that would set the ABS light on.
Couple of starts with it normal it would reset itself.
phox
Old 12-20-2003, 09:13 AM
Chip's Avatar
Dodgediesel4x4,
Keep an eye on your ABS and brake light and the speedometer. If the ABS and break light come back on and your speedometer jumps around from 0 to 20 mph, you may have to replace the speed sensor which is located on the top of your rear differential. Just a reminder !
Take care and good luck !
Chip
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
dieselJon
12-12-2007 09:53 AM
mr T
02-24-2007 06:42 AM
Quick Reply: ABS light on after RESCUING Z71
