ABS Code
did you try the the key trick to see if it shows any codes in your odometer.(turn the key on and then off three times with out starting) If that does not work probably need drbIII to read it.
DRBII tool is typically a dealer only tool. Some garages may have one, but not many. Did you get a code, when you turn the key from off to on three times? Any codes will display in order on the OD readout and the work done will display when complete.
Originally Posted by kingofdodge7131
whats drbIII, where do i pick one up at?
fitzydog
21
10-11-2017 12:09 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
