PDA
View Full Version : ABS & Brake lights??
Dusty 96
10-13-2002, 08:45 AM
a friend of mine has a 95' 2500 4x4 ctd, w/ a 5 spd. a while back his ABS & Brake lights came on , i put a new ABS sensor (the one on top of the rearend) in it & the lights still won't go out, any ideas???? thanks, dusty
Bob Beauchaine
10-13-2002, 09:29 AM
Try the micro switch on the brake pedal under the dash. If it is out of adjustment it will cause the brake lights to stay on. Good luck<br>Bob
USMC64-70
10-13-2002, 01:11 PM
I had a similar problem on my 1995 2500 a few months ago. It ended up to be caused from a worn out vacuum hose coming off the engine and going to the brake vacuum. Hose would partially collapse under pressure. Worth checking out. ;D
yomitch
10-16-2002, 12:49 AM
clean with contact cleaner or wd 40 the connector going into the sensor then pull the negative terminals to the battery wait 30 min or so and put them back on and computer should reset it
