ABS/BRAKE light on. what else do I replace
Old 01-31-2007, 12:58 PM
somis13's Avatar
I've changed the rear wheel speed sensor,brake light switch. and the lights dont come on til the truck gets up to 65 M.P.H. every time I drive it. I can hear the A.B.S. solinoids clicking when the brake pedal is depressed even at a stop. my vehicle is 2 wheel A.B.S. only. has anyone else had this? what else should I do besides take it to the dealer?
Old 01-31-2007, 01:40 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
i have the exact problem. if you figure it out, somis13, please let me know. i did all of the above AND followed the harnes from the rear axle foward as far as i could. still???????
Old 01-31-2007, 02:15 PM
RickCJ's Avatar
That's all you can do at home! Take it to a Dodge dealer and have the ABS scanned for codes this will tell you what is wrong.
Old 01-31-2007, 02:56 PM
TIMMY22's Avatar
im sure you tried a reset? either pulling the abs fuse for 30 sec with the key on or disconnect the batteries for 30 sec.
if it was a 96 or older you could do the codes yourself.
"Ah, hello is this my local 5 star dodge dealer? yes, I would like to make an appointment...."
Old 01-31-2007, 04:09 PM
somis13's Avatar
yes, if I pull the fuse for a few seconds then put it back the dash lights go off. then when its up to speed again they light up. I've put over 45,000 miles on the truck with this issue going on, so you can tell that I refuse to go to the dealer. it doesn't bother me anymore, I just know others have gone through this and hopefully someone will share the fix to keep the rest of us away from the dealer.
Old 01-31-2007, 05:38 PM
TIMMY22's Avatar
I think you could go to the dealer and get the codes read on the spot without
leaving sight of your truck. I know what you mean, I would not trust them as well. They will fix one thing and break 5 other things in the process.
Old 01-31-2007, 05:43 PM
xtoyz17's Avatar
My dads abs and ebrake light wouldn't go off. Turned out it was the ABS module or whatever they called it under the hood. The electronic portion bolts onto it, and all the brake lines thread into it. His is a 2001, though.
Maybe that helps,
Shawn
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
polaris800sp
04-07-2009 10:08 AM
mr T
02-24-2007 06:42 AM
Quick Reply: ABS/BRAKE light on. what else do I replace
