Abs, Brake and Air bag lights
Old 11-28-2006, 03:44 PM
gabbyfan's Avatar
I have a 1995 2500 with 365,000 miles on it. Every once in a while the Abs, brake and air bag lights will come on. Sometimes it is just the Abs and brake light but other times its all three. It seems to go away if I mess around with the dash by my knee whether i pull it out or push in. However sometimes that makes it worse and makes all three lights come on if only 2 were on. They usually are not on for more than 5 minutes. Any help would be appreciated
Old 11-28-2006, 06:26 PM
clutch1's Avatar
If you're messin with the pannel under the steering column just pull the pannel and check the wiring. If it changes every time you mess with it, it shouldn't be hard to find. Might just be a loose conector at the back of fuse block or the bulk head.
WhozNxtLS1
01-02-2024 05:43 PM
1stRam
08-14-2012 09:10 AM
polaris800sp
11-13-2008 05:35 PM
PZM123
02-05-2007 06:01 PM
Quick Reply: Abs, Brake and Air bag lights
