99 Cummins just dies
Old 05-21-2006, 06:27 PM
Louis's Avatar
This truck was given to me by my Dad who is now too old to drive. About 3 years ago it died on him on the highway. It did not sputter or miss - It was just like the engine was shut off. It was towed to Dodge and they could not duplicate the problem. It started once it cooled down. They did not do anything to it. It ran fine for about 3 years.Today it died while idling and it was the same deal. It was like someone reached in and shut it off. It would not restart at first. I waited about 5 minutes and it started and ran about 1 mile and died again. This time I did not try to start it until after waiting 15 minutes. It then started and got me home which was about 40 miles. I turned the AC off and ran the heater thinking it was a heat related problem. Not an overheating problem with coolant temp but maybe some sensor or something. When it runs it runs fine. It is a 24 valve 1999 6 speed. Any ideas?? Thanks.
Old 05-21-2006, 06:31 PM
Mike D's Avatar
Do you have any guages? Our trucks are known to have weak lift pumps, but without knowing what your fuel pressure is it would be tough to say.. If you do get a gauges there are two ports on top of the fuel filter canister that you can use to test...
vintovka
04-30-2012 12:38 PM
90 power ram
10-06-2011 08:04 PM
Joe V
12-13-2006 12:48 PM
sammy340
09-13-2005 07:03 PM
Mark3682
03-24-2004 10:59 AM
Quick Reply: 99 Cummins just dies
