99 Brake Question
Old 12-04-2008, 01:59 PM
collin_bucko's Avatar
99 Brake Question
For the truck in my sig I just have a few questions. I was running a little low on my brake fluid and I added some DOT 3 regulated brake fluid, and now whenever I get on the brakes I feel as if I have no working ABS and there is a sound of grinding that i get from the front. Could this be a worn down caliper making this noise or something else. I also know that the ABS is not working because we just got a good amount of snow the other day and I could lock up all four tires real easy under any bit of good pressure.
Old 12-04-2008, 07:36 PM
Mike D's Avatar
You can check your caliper pins to make sure they're sliding good.
Old 12-05-2008, 06:43 PM
dozer12216's Avatar
Sounds like brake pad(s) worn out Not unsual that abs will not unlock brakes on ice due to extremelly low resistance of surface. JMHO
coalburner400
08-01-2006 06:37 PM
2500TurboDodge
06-28-2005 09:52 PM
ddestruel
04-06-2005 11:26 AM
wvcowhauler
13
04-03-2005 11:39 PM
Quick Reply: 99 Brake Question
