98 ram hard to shift into 1st sometimes and not consistent ?
Old 02-24-2007, 07:54 AM
salvagesavage's Avatar
1998 ram nv 4500 hard to shift into 1st at stop lights but not all the time -is slave cylinder bleedable ? is this common problem ? anyway clutch works perfect and only six months old . but it is annoying sometimes trying to get in gear but if you try a couple times it will go normally ?
Old 02-24-2007, 08:04 AM
ckt_santiago's Avatar
Originally Posted by salvagesavage
1998 ram nv 4500 hard to shift into 1st at stop lights but not all the time -is slave cylinder bleed able ? is this common problem ? anyway clutch works perfect and only six months old . but it is annoying sometimes trying to get in gear but if you try a couple times it will go normally ?
It is more than likely your syncros. Try clutching to pull it out of 2nd bump the throttle then clutch again and hold light, but steady pressure on the stick.... Should work; it will cut the syncro's work load by closer matching the shaft speeds (they call it double clutching)
stanbnv
07-05-2011 11:10 AM
The_Head
05-10-2011 06:20 PM
Bruce M
04-04-2011 01:20 PM
Dave88LX
03-02-2007 04:23 PM
jb903
01-13-2007 03:47 AM
Quick Reply: 98 ram hard to shift into 1st sometimes and not consistent ?
