98 ford rims WILL fit on 03 Dodge (duallys) correct ???
Old 01-04-2008, 06:19 PM
Checkmate's Avatar
If I recall correctly....a dually rim off a 98 Ford will fit on an 03 Dodge dually right? I belive the metric pattern was brought out for the Fords in 99. Therefore I belive the lug pattern to be the same. My only question is if the hus are the same, meaning hub centered and the same size hole. Thanks, Dan
Old 01-04-2008, 06:31 PM
omaharam's Avatar
Yes. The only thing that would have to be different is the center caps.
Old 01-04-2008, 06:49 PM
04smoker's Avatar
Um? Not unless the 98 had 17" wheels. With 16.5's you have to grind on the caliper alittle to get them to fit. Correct me if I'm wrong.
Old 01-04-2008, 06:55 PM
Checkmate's Avatar
Thats cool, i'm not actually using a rim, just needed to know that the bolt pattern and hub hole was the same. Doin somethin else and tryin to save a lil. :-)
Old 01-04-2008, 07:18 PM
omaharam's Avatar
Yeah, I guess I was thinking aftermarket wheels, not stock. But the bolt pattern is the same.
13ALPHA
17
07-17-2010 09:24 PM
Palmetto_kid
02-27-2008 08:04 AM
chuckybones
02-11-2007 02:51 PM
Hippie816
01-27-2007 07:14 AM
Korney
15
05-25-2005 05:54 PM
Quick Reply: 98 ford rims WILL fit on 03 Dodge (duallys) correct ???
