98 3500 No Running Lights!!
Old 12-18-2011, 01:48 PM
ARbowhunter7's Avatar
Out of town and I lost my running lights. It started yesterday when I turned my lights on and only the headlights came on. Then, after around 2 minutes of idling, the running lights all came on. Assumed it was an isolated incident. Now (with nighttime rapidly approaching) I turned the headlights on and have ONLY headlights. No running lights, marker lights, etc. Brake lights and turn signals are fine. I can't find a fuse or relay for running lights.
Truck is a 1998 12V Ex. Cab Dually NV4500 4x4
Please help, as I need to drive at night. Thanks in advance.
Old 12-18-2011, 05:53 PM
dieselman97's Avatar
Headlight switch Prolly the culprit. Wiggle the **** around c it they turn on.
Old 12-19-2011, 10:25 AM
infidel's Avatar
Even if your truck isn't eligible for this recall get the parts and do it yourself> http://dodgeram.info/tsb/recalls/819.htm
Don't have to buy the parts from the dealer at inflated prices, several online auto parts including www.rockauto.com sell what you need.
Old 12-20-2011, 01:42 AM
atthepark's Avatar
If it isnt the switch, check the grounds. I had the same thing happen to mine and it was the ground contacts for the back half of the truck.
Good luck.
Old 12-20-2011, 06:47 AM
Switch was fried. Thanks a ton.
Sent from my DROIDX using Tapatalk
Banzai Bob
02-24-2010 12:24 AM
getrdun
11-26-2008 11:46 AM
cdn3500
10-28-2007 08:11 PM
Quick Reply: 98 3500 No Running Lights!!
