98 2500 Steering
Old 07-17-2006, 08:25 PM
xeus's Avatar
Post 98 2500 Steering
Has anyone had any luck tightening the steering gear box,in order to take some of the play out?
Old 07-17-2006, 10:07 PM
BCB
BCB's Avatar
yes, it tightened my steering up but i am still going to get a 3 turn steering box.
dslpower's Avatar
Steering adjustment
Yes you can use the screw to remove (some) of the play. Make the adjustments 1/2 turn at a time. Going too far will cause the steering gear to bind and not return to center. Makes the truck really hard to drive.
This wont take the slack out all of the wear in the box, but it will tighten it up considerably. OH yeah... your steering wheel will turn slightly to the right as the screw is turned in.
Old 07-17-2006, 11:50 PM
somis13's Avatar
what is a three turn steering box?
it sounds cool, where can I get one? My steering wanders also and I dont let my wife drive the truck for that reason. Oh and how much are they?
Old 07-18-2006, 10:08 AM
xeus's Avatar
You say when you tighten up the box you get a slight turn to the right.Can this be offset with a new wheel alignment?
Old 07-18-2006, 12:28 PM
BCB
BCB's Avatar
they are $200 i'll see if i can dig up a link.
Old 07-18-2006, 12:57 PM
BCB
BCB's Avatar
this is all i could find for now but it gives you some backround https://www.dieseltruckresource.com/...g+steering+box
there was a big thread on it not to long ago i'll keep looking
edit... found it http://www.powersteering.com/ call them and talk to them
joebishop23
10-29-2007 10:19 AM
mattsdiesel06
15
01-25-2006 08:39 PM
ALEX516
09-15-2005 09:14 PM
Bigredmachine
06-24-2004 12:36 AM
03CTDCO
11-18-2003 08:11 PM
Quick Reply: 98 2500 Steering
