'97 Interior Switch Out
Old 11-21-2008, 07:07 PM
soypwrd's Avatar
My new '97 has just come back from the paint shop the white that I've wanted. Now the only thing that would make this truck just what I want would be a beige interior, rather than the grey it now has.
Would any interior from '94 to '02 be a easy change out or are there specific years that would be a snap. It's be nice if the '02's would work, as I'm more likely to find an interior in good shape from those later years, at least in as good shape as the one I now have at a well cared for 59K.
Old 11-22-2008, 05:50 AM
cmac's Avatar
they changed the interior for the 98 model. the newer interior has the seats with the seatbelts in the seat. i'm pretty sure the mounting of the seats is different to accomidate the strength required for the seatbelts. so anything from 94 to 97 should be a direct swap as far as mounting and brackets.
Old 11-22-2008, 12:37 PM
rollerink's Avatar
I have been trying to figure out the same thing for my '96. I have been wanting to update the interior for a long time and here's a couple of things I found out. If you want to get newer seats from a 98-01 you have to get the from a regular cab. Also any door paneling has to be from a regular cab as well. Hope this helps you out
Old 11-22-2008, 12:45 PM
torquefan's Avatar
I would assume you are changing the dash too. If so, I'd stay away from the 98 or newer as the wiring is quite different. Specifically regarding the addition of the Central Timer Module. Cluster wiring, door switches etc. are all different.
pik
11-27-2016 02:26 PM
Copenhagenjunkie
12-21-2007 06:00 AM
Dieseljunkie
02-08-2007 10:17 PM
Vintage Empire
12-20-2005 10:02 AM
patriot pearl blue
12-29-2004 06:47 AM
Quick Reply: '97 Interior Switch Out
