97 3500 tire size ?????
1 Post
What is the largest tire I can fit on the truck , I think it is 235-85 -16 but not totally sure but would like to know before buying them. Thanks
Ive seen them
with 255/85/16's, A friend of mine runs them on his dually with no spacers and no rub, However, he dont tow much with it, that i know of.... If you want spacers, i have seen guys that run 37's on their trucks..
Tx
Tx
235/85's are about the largest tires you can put on without rubbing and not having to use a spacer
I run these tires and with a heavy loaded trailer I keep my tire pressure at the tires max pressure of 80 psi
I had a Furd dually pass me a couple of weeks ago and when he pulled back into my lane I notice his rear tires had no spacing between them about 10 miles later I pulled in for fuel and this Furd was also fueling up....I walked over and asked the driver if his rear tires where rubbing......after a dumb look on his face I bent over to look and his sidewalls where worn to the cords....after he looked at it his only words where the tire salesman said it would be OK
bigdogtruck
18
11-21-2007 08:09 PM
MoreSmoke
07-14-2004 12:54 PM
