97-01 brakes
Old 02-25-2009, 10:10 PM
97 D-Tec's Avatar
97-01 brakes
Did anything change in the front calipers, or there mountings from 97 to 01. ive heard they went to dual piston calipers but ive never seen one to look. If they did how do they mount up? does anyone know if they mount in the same location as the single pistons on a 97? Id like to mount the dual pistons up front if i can.
Old 02-26-2009, 07:43 AM
patdaly's Avatar
Look for the big brake thread, yes things changed, and us older guys cannot upgrade.
Old 02-26-2009, 09:58 AM
infidel's Avatar
Read this thread first https://www.dieseltruckresource.com/...ad.php?t=46618
Old 02-26-2009, 10:38 AM
John Faughn's Avatar
Bill does that thread ever get to front calipers , after 11 pages , I have not found anything about front calipers , I thought I saw something a while back about changing out calipers ?
Old 02-26-2009, 10:47 AM
infidel's Avatar
Lots of work to improve the fronts.
Most folks find that when the rears start doing their fair share of work with the larger cylinders that the stock fronts are fine.
Old 02-26-2009, 12:11 PM
patdaly's Avatar
This is the one I was referring to........
https://www.dieseltruckresource.com/...upgrade&page=3
Old 03-01-2009, 09:25 AM
97 D-Tec's Avatar
well ive been looking at the big brake thread but theres no info for the 2wd guys and i noticed the part number for the gm wheel cylinders but i dont see a 4637337 i only see a 37337
Old 03-01-2009, 04:35 PM
infidel's Avatar
4637337 is an old Napa number. Now they have removed the 46.
Old 03-03-2009, 07:10 PM
nickg's Avatar
I recently installed hawlk pads, cant say they are any better, than the high end bendex I was using, hawlks are quieter and more expensive, and dont bite as good as the bendex did. anyway I digress I went to a local parts place and they are ordering me the brake caliper brackets. I think they are going to be under 30$ perside or I could order new calipers and brackets for around the 75$ range. Hopefully tonight I'm going to pick up a set of 17inch factory rims for my future brake upgrade. I eat a set of expensive pads every 20,000kms or 4 months, and thats with ensuring that the rears are adjusted every month, if I dont keep the rears adjusted fronts last 1.5-2.5months tops. I also have the chev rear wheel cyls and have extended the prop rod as well.
I wish I had seen this thread last year, cause I'd have done it already!!
Old 03-03-2009, 07:11 PM
nickg's Avatar
To do a 01 truck all you need is a set of rotors couple brackets and a set of 17 rims.......... pretty easy I think, no so for the older trucks
wildcargo
11-29-2005 04:20 AM
95black2615
08-22-2005 09:21 AM
JImbo1
13
04-18-2003 06:44 AM
Quick Reply: 97-01 brakes
