96 auto trans?
Old 03-11-2007, 09:27 AM
058hamer's Avatar
96 auto trans?
hi im new here i need to know what the best thing to do to my trany it works fine now truck will end up a 11000 pound service truck ps its the hd trany
Old 03-11-2007, 09:51 AM
tactransman's Avatar
Transgo shift kit for starters,then maybe a triple clutch converter.
Old 03-11-2007, 12:29 PM
vssman's Avatar
You have the 47RE tranny in your 2500. For starters, as mentioned above I'd go with either a shift kit or aftermarket valve body from one of the 'big boys' (DTT, ATS, Suncoast, Goerend, etc...). Personally, I did the Trans-Go and after a few years of not being satisfied with the shift points (and many, many adjustments just to get it where it was) I changed to a DTT VB. All I can say is that the new VB is a night and day difference form the trans-go. With the T-G shift kit, it wouldn't downshift to 1st when I came to a stop unless I actually stopped. With the DTT, it'll shift back to 1st at approx 17mph. Also it's a bit quicker with the shifts correctly spaced on the DTT and I have a LOT less smoke when I roll through a stop sign. I'm sure all of the other tranny companies have VBs that perform similarly as they all are bench tested and set up properly. After the VB, I'd change out the torque converter for a lower stall speed (tighter) one.
Old 03-12-2007, 04:13 PM
058hamer's Avatar
does the transgo kit engage the first gear band in drive? is the factory band specs the best ones to use? and whats the best fluid? thanks
Old 05-24-2007, 05:25 PM
058hamer's Avatar
just got my transgo kit today havent had time to read all of inst yet but i didnt see a resister mentioned do i need to add a resiter if so what value and what wire? tnx 058hamer
Old 05-25-2007, 03:07 PM
058hamer's Avatar
never mind i see the resistor kit in the box 058hamer
DodgeDiesel61
06-03-2008 07:50 PM
lews930
03-07-2007 06:33 PM
spitfire9137
03-10-2006 06:29 AM
ezdemon72
07-29-2005 10:05 AM
ckennedy
09-27-2004 11:58 AM
Quick Reply: 96 auto trans?
