are the 96 and 97 front frames the same? fisher plow setup?
Old 11-29-2006, 09:28 PM
GR40RCapri's Avatar
Hey guys...
my brother's truck is a 97...he's not going to be using the plow mounts, and i need them for my 96...are the frames the same? it seems the fisher website shows some sort of difference...it seems insignificant though...then again...their directions are a bit confusing; as they group 1500, 2500, 3500 together in one set of directions, then totally seperate in others...
http://www.fisherplows.com/pdf/64065.01_091505.pdf
thanks for any/all help
J
Old 11-30-2006, 07:51 AM
TIMMY22's Avatar
they both require push plate kit #7157
go to there e-match link and play around with the year and body styles.
http://www.fisherplows.com/ematch.asp
click on start e-match.
Old 11-30-2006, 09:20 AM
gmctd's Avatar
2wd frame is similar but not identical to 4wd frame because of suspension components.
Old 12-02-2006, 12:42 PM
GR40RCapri's Avatar
It seems that there are slight differences in the 96 and 97 frames...such as more support for the shock towers in the 97... i thought that was interesting..
thanks for the help guys...the plow plates are the same..
J
sr148
12-06-2006 09:30 PM
gn1270
25
10-15-2006 06:42 AM
BigDave12768
08-06-2006 07:37 PM
Walt L
12-25-2004 10:13 PM
Quick Reply: are the 96 and 97 front frames the same? fisher plow setup?
