95 12v tc lu question
Old 09-13-2011, 08:14 PM
plugless1's Avatar
how do i wire my tc loc up to a switch? and what kind of switch do i need?
Old 09-14-2011, 07:55 AM
esde's Avatar
standard on/ off switch, push or toggle whatever flavor you like
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old 09-14-2011, 10:22 AM
infidel's Avatar
Just make sure if you use a lighted switch or indicator light that the switch has two sets of poles, STDP.
If you don't juice flows though the bulb filament and will mess up the lockup function.
Old 09-16-2011, 08:28 PM
plugless1's Avatar
great guys, on the way to the switch rack! thanks for the link also
Old 04-10-2013, 12:25 PM
mtdoragary's Avatar
Can I wire it to an oil pressure switch instead of ground so that if it drops to idle it will drop the lockup?
Old 04-11-2013, 11:47 AM
infidel's Avatar
You can do this instead. On '95 use PCM pin 54 instead of B11
Old 04-11-2013, 12:36 PM
Lil Dog's Avatar
Holy smokes! That is some system.
Old 04-11-2013, 12:44 PM
joem's Avatar
I really want to be able to lock 2nd for windy steep mountain roads as I haul a 18,000 lb Hatachi EX60 up 18% grades to dig watering holes for wild game. My old duramax was able to shift locked but I here we don't want to let the 47 series makes its shifts while keeping the converter locked?
Old 04-11-2013, 07:09 PM
gorms's Avatar
Not a bad idea, I'm sure they do make adjustable hobbs switches with n/c contacts. Could just run the lockup ground through that first and have the hobbs open up at your set oil pressure. Or use a common normal open switch to hold a relay. Only problem I could see with that is higher pressure in cold weather (on my truck anyhow) could make it inaccurate till it warms up. Other wise try it! I think the port on top of the oil filter housing (1/8" MPT plug) would work.
Also for 2nd gear lockup (manually selected 2nd gear) you need to pull apart the VB and block up a passage in there... google it, it works. I never had any catastrophic damage directly from shifting while locked up, but I wouldn't say it makes anything last any longer either.
edit: Here ya go adjustable hobbs switch, not sure on the range but can get with n/o or n/c contacts here.
Old 04-11-2013, 07:59 PM
mtdoragary's Avatar
Well-thought-out hookup!
03CumminZ4X4
02-01-2008 11:15 PM
Russell_d
02-25-2007 09:12 AM
CTD2001
02-03-2007 01:30 PM
apache
10-27-2004 08:53 AM
Quick Reply: 95 12v tc lu question
