94 -2500 4x4 4wheel drive unit
Old 11-01-2011, 06:20 PM
cminzey's Avatar
Ok here's the problem My 4 wheel indiactor isn't working I depressed the pluger on the switch but nothing I also tried jumping the wire to make the light work still nothing is there something I am missing I am trying to find out if it's the axle accuator or something else It has 160k on it and I have not replaced anything on the 4 wheel drive at all yet it worked fine last year now no light and I am not sure it's engaging
Old 11-01-2011, 06:47 PM
rebal's Avatar
did you check the bulb? test the switch? have vacuum? also this should be in 2nd gen section
Old 11-01-2011, 07:13 PM
1st Generation Admin
BC847's Avatar
Moved to the 2nd gen board.
Old 11-01-2011, 08:05 PM
RCW
RCW's Avatar
Trying to trouble shoot those units is like pushing a rope. To test the light you need to get into the dash, to test the actuator you need to remove it and get help cycling it. If it is the relay, good luck trying to test that. When you are near 100 you will find the problem.
My solution is to simply replace the OEM junk with a Posi-Lok manual shift system. If the cable is pulled you are locked!
Old 11-02-2011, 10:35 AM
infidel's Avatar
$30 Posi-Loc> http://www.jeepforum.com/forum/showthread.php?t=595515
Black Dog
07-31-2010 11:13 AM
Buckshotram
01-14-2006 12:01 AM
Jim Weed
03-18-2005 04:07 PM
CumminAtYa
09-23-2004 12:14 PM
Quick Reply: 94 -2500 4x4 4wheel drive unit
