View Full Version : 93 Performance questions....
miracle_boy9
05-06-2007, 06:46 PM
Hi,
I'm brand new here. I live in Canada and just purchased a 1993 Ram 250 Club Cab. The truck is all stock right now and i am wondering how to go about modifying it in stages. Where should I start? Which upgrades will give me the best bang for my nuck...any help is greatly appreciated!
Short Box
05-06-2007, 07:19 PM
Welcome to the club!! I am also from Canada and fairly new to this site(about 5 weeks).If you are like me you will be spending hours on here reading and learning about your new truck, there is no shortage of info and shortly you will have all kind of suggestions. Also go to the top left corner, click on user cp and fill out your signature.
DanMan
05-06-2007, 07:22 PM
Welcome! I too am relatively new.
As for mods, before even touching the pump or engine you need a set of gauges. EGT and boost are good starters, then a tach. There are 1 and 2 gauge A-pillar pods available for the 1st gens.
93beater
05-06-2007, 10:26 PM
guages!!! trans, pyro, boost, then tweak the pump +2 full fuel, lower idle, max afc, -1 smoke screw, then grind your fuel pin or buy 1, and remove the washer, 3200 rpm spring, afc spring etc... good luck!
