91 250 w/CUmmins need more power!! Help
Old 04-12-2006, 01:57 PM
raybob_99's Avatar
Was wondering what all i can do on a budget to get more power out of my 92 250 Dodge. It has auto. trans and is 4x4. I thought about buying a BHAF and straight pipe. Is there anyway to put later model turbo on the truck? Hope you guys can help.
Old 04-12-2006, 04:07 PM
apwatson50's Avatar
Straight pipe and BHAF is a good start, although neither will give you a SOP feel in power, they will allow you to use power once you give it enough fuel.
Read these articles found in the faq section:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Those should get you going pretty good. Cheap easy power upgrades.
Old 04-12-2006, 04:12 PM
jiMMyCTD's Avatar
i put about 1500 bucks into mine and it will move ya. Yes you can put a late rmodel turbo on. you pretty much gain the whistel and wider boost range. its the exhaust housing that you benifit from for quick spools.
Old 04-13-2006, 09:56 PM
raybob_99's Avatar
More Power
Is a direct bolt on for a 2001 HO turbo? What should i do, just use exhaust housing or what? Thanks for help.
Old 04-15-2006, 12:11 AM
smokin92's Avatar
Well first do what you were going to do and then turn your pump up and find a 12cm housing for it and you will notice a big difference cause if it is a 92 you have the 21 cm housing
Greed 93
01-31-2010 09:26 PM
smoky beast
02-26-2007 09:17 AM
philobeddo
06-15-2006 06:16 PM
Captain Dean
04-30-2006 11:01 AM
guh2stroke
12-24-2005 08:45 PM
Quick Reply: 91 250 w/CUmmins need more power!! Help
