7 Pin Wiring Help Needed
I installed a Voyager controller and I had to install the 7 pin connector after market as I didn't get the factory 7 pin with it. I bought the wiring harness from Dodge and ran the "blue" wire for the electric brakes directly to the Voyager controller.
In upgrading I can't find the directions for the wiring harness install to connect using the Dodge/Prodigy wiring harness. All other wires are connected and I have power to the controller but do not have the "blue" wire connected.
Where does the "blue" wire connect under the hood to supply power to the electric brakes? I know I can tap into the blue wire at the trailer plug or wiring harness but want a neat, clean install.
Thanks for your help.
Stevenc
11-21-2003 09:05 AM
