68re in 2005??
Old 03-28-2011, 09:08 PM
crazybryan's Avatar
68re in 2005??
Anybody try to get a 68re in a 3rd generation truck?? If so how is it??
Old 03-28-2011, 09:19 PM
cbrahs's Avatar
nope. 48re in 03-07 with 5.9 68rfe is in 07-current trucks with 6.7 engine
Old 03-28-2011, 09:23 PM
crazybryan's Avatar
I was just wondering if it was a stronger tranny?? It would be nice to have one more gear
cbrahs's Avatar
they are 6 speeds. 48re is a 4 speed. 2 more gears brother
Old 03-28-2011, 09:32 PM
rockcrawler304's Avatar
It won't work "yet" because of the electronics involved to run the 68RE.
Old 03-30-2011, 08:59 PM
PoorMansCat's Avatar
I have posed this question several times on various sites..... actually I would rather transplant the Aisin 6 speed fromt he C&C trucks....
while the 68re has two more gears and WOULD be an advantage, I'd jsut as soon got with the more bulletproof Aisin...
Somebody PLEASE work on a standalone controlller.. !!!
Old 03-30-2011, 09:04 PM
cbrahs's Avatar
the cab and chassis trucks power is derated compared to the standard trucks. transmission has NO aftermarket parts at all and both the cab/chassis trucks and standard trucks transmission ARE 6 speeds (standard trucks transmissions have aftermarket parts now and I was told by many aftermarket manufactures that there will be NO aftermarket parts for the cab/chassis trans)
Old 03-31-2011, 07:26 PM
bkrukow's Avatar
You can put a Alison in it. THere are stand alone controlers for them as well as adaptors to bolt it to the Cummins. I REALY wnat to convert mine to a 6 speed manual but I may consider converting it to a 6 speed auto if I have the money when the crapy 48re goes out. If a controler for the 68re is available at that time i will go that rout to keep it cheaper but if not a built Alison is not out of the question.
Dodgezilla
17
05-20-2008 07:49 PM
Dieselnick
01-12-2008 09:50 PM
supercharged_hp
93
06-10-2007 05:30 PM
Syndicate
04-10-2007 09:57 PM
Berak
13
03-06-2003 12:30 PM
Quick Reply: 68re in 2005??
