60lb valve spring install
Old 08-03-2010, 05:28 PM
TXlilbro's Avatar
hey guys im about to get my 4k GSK and 60lb valve springs, my question is how hard are the valve springs to install? i work at an auto repair shop and have tools but not much for diesels. do i need anything special?
thank you
Old 08-03-2010, 05:47 PM
1st Generation Admin
BC847's Avatar
See if this'll help ~ https://www.dieseltruckresource.com/....html?t=171288
Old 08-03-2010, 06:20 PM
lgp9999's Avatar
I took a typical **** style overhead valve spring compressor and cut off the **** and welded on a nut to turn with a wrench (for cylinder 5 and 6 under the cowl). Once you compress the spring, bar the engine over and have someone watch for the valve to be pushed up by the piston.
Repeat 11 more times.
JBradley500
05-24-2011 08:50 PM
c12h26
07-05-2009 08:13 PM
PourinDiesel
09-18-2007 06:55 AM
goodtyms
06-14-2006 08:04 AM
ihpower
10-21-2005 03:35 PM
Quick Reply: 60lb valve spring install
