600 Juice/Attitude guys..........
Old 01-24-2005, 11:38 PM
1TONY1's Avatar
Anybody else have this:
My maximum boost varies from one full throttle pull to the next. One time it will peak at 26 - 29psi and the next pull it may go to 38 - 40psi. I have the max boost setting way up (60+) and the truck is fully warmed up (185+) I am doing the same thing everytime .... 3rd gear, 1800 rpm, then full throttle. I called Edge tech and I think the tech was more confused then I am on how and what controls the boost.
I really wish we could raise the full cut off. I sure do miss my governor springs on the 1997 Dodge. I wonder when this 600 starts defueling.
Old 01-25-2005, 12:31 AM
treeman's Avatar
You should have settings that you can max. your boost so it will defuel
Check your manual
Old 01-25-2005, 08:27 AM
Lightman's Avatar
Treeman I think he knows that because he said he has it set at 60+. That's strange Tony, considering all factors are the same. I'm interested to hear if everyone else is getting consistent readings.
Old 01-25-2005, 10:14 PM
1TONY1's Avatar
Yes, I have it set HIGH to make sure it does not effect what I am seeing for max boost.
Old 01-26-2005, 01:36 PM
bigblock2stroke's Avatar
145 cubic millimeters of fuel per cylinder per cycle max on 610 motors.
Old 01-28-2005, 09:38 PM
1TONY1's Avatar
What does that have to do with the boost and my Edge box ?
Tyler_02
01-24-2006 09:09 AM
codered
06-29-2005 05:22 PM
RankRam
04-06-2005 02:13 PM
RamWheelsBy4
03-19-2005 09:03 PM
Big Bob
12-24-2004 04:10 PM
Quick Reply: 600 Juice/Attitude guys..........
