6-speed shifter
Old 10-10-2006, 12:02 PM
stock03's Avatar
Question 6-speed shifter
Anyone know how to stop the plastic cover/ plate (the one that sits on top of the shiter) that shows the shift pattern from rotating?
Old 10-10-2006, 12:08 PM
sumner's Avatar
Hey man, Heres what I did.... I just pryed the cap out with a small regular screwdriver. They take a pocket knife and push the blade into the lip on the inside of the cap several times all the way around the cap, then, just pop it back in. Only takes a few minutes... Hope this helps...
Old 10-10-2006, 12:22 PM
stock03's Avatar
Cool, thanks sumner.
I guess after I re-set it, I can just glue it so it doesn't spin again? Did you do something to prevent yours from spinning again? My brother's 02 does the same thing. But I'll pop it off and fix it.
Old 10-10-2006, 01:22 PM
35" 05''s Avatar
mine does the same thing. does anyone know where i can get a big rig shifter to fit?
Old 10-10-2006, 01:30 PM
getblown5.9's Avatar
i stopped that in my 02 by putting an srt-10 shifter in. when you tighten the ball and nut onto the shift lever it cant rotate. plus its leather and brushed aluminum. looks great in there.
Old 10-10-2006, 02:15 PM
MikeyB's Avatar
I have a white Hurst shift ball on mine. A machine shop made a 16mm to 10x1.5mm adapter so it could fit on the shift lever.
MikeyB
Old 10-10-2006, 03:17 PM
XLR8R's Avatar
I just let mine turn whichever way it wants - but the truck never seems to drive the same way twice....
Old 10-10-2006, 03:34 PM
dodgezilla04's Avatar
where are you guys getting your srt10 shifters at? since I am short, and have to pull out the shifter to get the trans out for clutch replacement, why put the factory tree branch back in?
Old 10-10-2006, 10:09 PM
nickleinonen's Avatar
search for tommygun on this site
Old 10-11-2006, 11:27 PM
tacohat's Avatar
Another way to stop it from turning is to take the shift pattern plug out by prying it out with something like a knife, re-install it in the position that you want, then pry open one little spot big enough to get one small drop of glue in there. I used a tiny little drop of Super Glue and it hasn't turned since.
Old 10-12-2006, 08:36 AM
stock03's Avatar
I'll try that, thanks
Old 10-12-2006, 10:35 AM
misplacedtxn's Avatar
I glued mine about a yr ago and still good
Old 10-12-2006, 12:03 PM
thanks nic
Old 10-15-2006, 08:35 PM
Rod_Montana's Avatar
super glue - the runny stuff
I waited 4k miles until it lined up 6-12 oclock again and then dribbled in some of the runny super glue around the edge. Got 5k miles since then and it's still stationary.
Old 10-15-2006, 08:49 PM
whoahoss's Avatar
THE 98.5 HAD EDIT on it
wife made me take it offf
Quick Reply: 6-speed shifter
