6-speed shift knob rotation
Old 07-30-2003, 08:30 AM
LonCray's Avatar
6-speed shift **** rotation
I've had my '03 2500 since last October, and my shift **** has taken to slowly rotating. It's been thru one complete rotation and is just starting it's second - moving clockwise. Funny thing is, I can't turn it myself either direction, and I don't know if it's just the leather **** or the entire shaft that's moving. Is anybody else having this problem? If so, how do I make it stop?
Old 07-30-2003, 08:37 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
Re:6-speed shift **** rotation
Haven't seen it on this one yet, but did have the same thing happen on the Chevy S-10 I drove in college. Doesn't hurt anything....unless you are one of the ones that have to look at the little diagram to figure out what gear you're going into. Then you could have issues... ;D
Old 07-30-2003, 08:38 AM
erslll's Avatar
I am very curious to hear if anyone else is having this problem and why. I am seeing the same thing happening to mine. Anybody with any info? TIA
Old 07-30-2003, 08:39 AM
Hoss's Avatar
There's two. Time for the TSB to come out.
Old 07-30-2003, 08:54 AM
Mexstan's Avatar
Mine used to do it but I fixed it. It is not the **** itself rotating. It is locked in place with a locknut under the plastic thingy that shows the shift patterns. It is an easy fix. Using a small screwdriver or similar tool, gently work it under the plastic thingy and pop it out. Place one SMALL drop of adhesive in ONE place on the plastic, line it up properly and pop it back in place. Don't go overboard with the glue in case it is necessary to remove the **** later.
Problem solved and no TSB required.
bulabula's Avatar
Mine's upside down right now. Not sure how many rev's its been. I wouldn't worry about it, and keep your eyes on the road.
Old 07-30-2003, 02:24 PM
doug's Avatar
carryover problem from 02. I'm on my third shift **** -- its the **** itself. When my 02 was new, the **** rotated 90 degrees in the first 3 months. I took it too the dealer and they replaced the ****. the new **** worked great -- stayed put and all of that, until recently when it has started to move again.
tell them you depend on the shift diagram ;D. But seriously, get the dealer to take care of this under warranty.
Old 07-30-2003, 02:37 PM
FiverBob's Avatar
HHMMMMM, the case of the shifty shift ****. Now you have disturbed my sleep. I will have to come out tonight and sneek up on it and see if it is playing around. ;D ;D
SherlockBob
Old 07-30-2003, 03:27 PM
doug's Avatar
heh heh heh. yea I'm with you on that Gary, but another part of me wants to hold DC responsible for even the little things. ;D The dealer actually tried the locktite thing first w/o success. then they changed the whole ****. I was even putting little pieces of tape with index marks on them to prove what actually was rotating.
Anyway I figure if they want to change parts until they get on that won't turn, that's ok with me :-). looks like if I go the 04 route I'll be re-visiting the shift **** thing!
Old 07-30-2003, 04:27 PM
bulabula's Avatar
I wonder if I document it with DC, do ya think they'd reimburse me for one of Scotts' custom ***** and call it even? ;D
Old 07-30-2003, 07:14 PM
mymaur's Avatar
In my case MEXSTAN is right. Not the ****, but the plastic insert that marks the shift pattern. It has rotated 90 degress in 10,000 miles. So at 40K it will be straight again.
Personally, I wouldn't waste my time and loose the truck for a day to have the shift pattern relocated to the correct position. :
Old 07-30-2003, 07:28 PM
erics76's Avatar
Just leave it upside down, maybe if someone tries to steal your truck, they won't be able to shift it! ;D
Old 07-30-2003, 09:06 PM
100 Proof's Avatar
Location: Eagle, Idaho. Please set your watch back 20 years when entering.
Mines at 2,800 miles and the gearshift "thingy" is on lap 2!
100 Proof
Quick Reply: 6-speed shift knob rotation
