6 speed manual problems
I have a 03 with 6 speed manual trans. It is getting hard to get into first and reverse, reverse more than first. When I first start it up not a problem but after I have driven it for while it gives me problems. Anyone had any problems like this?
Could be several things. First, when was the last time the fluid was changed? Sometimes new fluid will help with cranky shifting. Second is the hydraulics, maybe getting weak.
I found that shifting into 5th before going into reverse helps a bunch.
MikeyB
MikeyB
1 Post
Mikeyb is right, try a fluid change if it has been over 65k, if it still is hard to do then try pumping the clutch several times if that works then hydraulics are eak
6 speed problems
I did change the fluid after it started acting up, did'nt help. I will try pumping the clutch to see if it is the hydrolics. Thanks for the info.
A big possibility is that the pilot bearing is starting to seize, and won't allow the input shaft to completely stop turning when the clutch is disengaged.
I think so too, if you're going to all the work to take it apart might as well change it while you're there.
Let us know how it goes.
Burkert
21
11-26-2007 07:09 PM
MossyOakGlock
18
09-21-2007 03:42 PM
ezdemon72
07-29-2005 10:05 AM
