PDA
View Full Version : 6.7 starting
Nigel R
04-03-2009, 09:23 PM
my 6.7 cranks alot before starting when restarting warm? No codes showing.
Lil Dog
04-03-2009, 10:05 PM
Just started doing this or has always done it?
Harvie
04-04-2009, 08:04 AM
Turn the key to "on" and leave it for 30-45 sec before you try cranking.
My old one would fire right up the 9 6.7 cranks longer but much less when leaving the key on for 30-45 sec.
Scotty
04-04-2009, 11:01 AM
Other then when I have the wait to start light on, I start asap. 116,000 miles and have not experienced long cranks. It fires within a second or two...never really timed it...seems pretty much fired up instantly.
However, a friend of mine had a similar situation with a very new [less then 5K miles] truck. Just for the heck of it he changed out his fuel filter and it starts quick now. maybe some poor fuel from the factory? Who knows.
Scotty
hiperffun
04-22-2009, 12:15 PM
My truck now has 11,000 miles and has always turned over several times
before starting.
xb9rumble
04-23-2009, 01:02 AM
Mine will fire right up half the time and will crank for a couple seconds the rest. Only 9k miles and it has been doing it for ~3k miles
DarkDesertCTD
04-26-2009, 09:52 AM
When my wait to start light is on I wait and then it fires right up. when it's not on I start it and it cranks once and the second time it starts. 08 with just under 5K miles
Nigel R
04-26-2009, 05:10 PM
thanks for replies ,it is better if I wait afew seconds before hitting the starter.Cheers Nigel
Quick
04-26-2009, 08:41 PM
mine too - longer when warm. fires right up when cold
boatpuller
04-28-2009, 12:11 PM
my 6.7 seems like it cranks a little longer before it fires then my 5.9 did.no biggie,just something i noticed.
rbmedic75
05-05-2009, 12:47 AM
check to see if you need an updated flash from dodge :( I know but there was a TSB about extended cranking times i was also said to pick up 3 MPG or so with just the updated flash. Most have to be plugged into the scan tool to find out which flash they have but a good dealer ship will do this under warranty if you tell them your having the extended crank times. PS eventually the check engine light will come on but i dont remember the code of hand
jthorpe
05-21-2009, 10:45 AM
I'd be curious in hearing more information about this. If there is an answer, I'd like to post it on the wiki and in the forum.
ratlratl
05-21-2009, 09:53 PM
I always wait for the 5 dings before hitting the start button. Of course the wait to start in the winter, but any other time I just wait for the dings. Don't know why they are there but must be something.
Chris
