5th gear, 2800 rpm, defueling with 3200 spring
Old 12-19-2006, 06:57 PM
pred's Avatar
Since I replaced the head gasket on my truck, I have taken it real easy, Just running it a bit, and just put new tires on, Stuck in alot of traffic today, Getting a little bored, when traffic finally opened up, we were all moving nicely at about 80 mph, SSSSOOOOO i thought like seeing what the old girl has in her, Well i flipped on the H2O/meth, and slowly introduced the pedal to the floor, and she pulled Great till about 2800 rpm, and started to fall on her face, Figuring I started to defuel somewhere in the 2800 rpm range, I kept er there for about 30 sec, My speedo never reads over 65 or so, I dont know how fast i was traveling at 3K rpm, But it was really smooth!
Is it time to think I am starving the VE pump?
I still have the stock lift pump.
Does anyone else notice this defuel before 3200 rpm?
In 3rd or 4th I can pull real hard right to 3k, Just not as good in 5th,
I have the 354 rear
265/75/16s in the back, and a getrag.
Thanks for any imput about fuel, or speed at 3k in 5th.
Peter.
Old 12-19-2006, 06:59 PM
haloman's Avatar
You were easily 105-110 at 3k. I am at 95 at on the floor at the stock 2600 rpms.
Old 12-19-2006, 07:34 PM
GLHS's Avatar
By backing out the high idle screw and some grinding on the linkage stop, mine would defuel around 3100 with the stock spring and rev out to 3600. With the 3200 spring (why is it called that?) it now defuels around 3600-3700 and can rev up to 4000-4100.
Kurt
Old 12-19-2006, 09:51 PM
pred's Avatar
Kurt, is this rev under load in top gear?
Peter.
Old 12-20-2006, 08:47 AM
timb's Avatar
Mine did the same thing till I put the diaphram lifrt pump in. Now it pulls to 3400 RPM.
Old 12-20-2006, 09:36 AM
Boatnik's Avatar
You really meant piston pump didn,t you?
Old 12-20-2006, 06:56 PM
Time for a fuel pressure gauge.
Don't waste money on the piston pump, put on a Walbro. I resisted it for a long time (because I'm a luddite at heart ), but now I can't see settling for anything less.
Old 12-20-2006, 09:05 PM
timb's Avatar
Yes I did mean the piston pump. It was a long night at work. Thank's for pointing that out.
Old 12-21-2006, 04:31 AM
pred's Avatar
I will go and find a sutiable gauge, and install it in the cold soon. I think that my stock lift pump has reached it's limits. Will be interesting to see my fuel pressure.
Peter.
Old 12-21-2006, 09:59 AM
Begle1's Avatar
Oh, thanks a lot Dave.
I'll show you a freakin' Walbro...
Old 01-02-2007, 03:31 PM
GLHS's Avatar
pred; That is on a dyno in 5th which is around 122 mph @ 3600. I've had it to 115 or so on the road.
LemonDodge
09-16-2010 07:33 AM
KRB
12-17-2006 03:04 PM
charger 69
05-28-2006 08:01 PM
wyomingsmoke
08-04-2005 12:47 AM
mcevins
01-12-2004 12:06 PM
Quick Reply: 5th gear, 2800 rpm, defueling with 3200 spring
