5spd to 6spd swap
Old 05-24-2006, 10:24 PM
Smooshy's Avatar
5spd to 6spd swap
Howdy,
I droped my driveshaft a while back on the interstate which tore up my transfer case. I am about to go to some salvage yards for a transfercase and I started thinking, what if I luck out and find a cool 6spd along with a transfer case.
That being said is there anything weird I should know about with tranny differences? I'm a wrench but new to Dodge. Clutch and Flywheel differences?
Already welded up my home made frame spreader
2000 Dodge 3500 *** mins 5spd Dually 4x4
Old 05-25-2006, 07:53 AM
displacedtexan's Avatar
This won't be much help, but I know it has been done. Chris (signature600) has a 6 speed behind his 12v... I'm thinking he has said it was a pretty simple swap.
Old 05-25-2006, 08:04 AM
Copenhagenjunkie's Avatar
6 speed is longer so front driveline is longer and rear is shorter, takes a different clutch and pressure plate.
Old 05-25-2006, 08:05 AM
rich's Avatar
you need the clutch and flywheel, the tranny support is moved further down, driveshaft work to shorten it i believe. if you are lucky and can find a 6spd cheap you better buy a lotery ticket cuz you are very lucky. ive looked and the cheapest i have ever found was about 3 grand
Old 05-25-2006, 11:10 PM
Smooshy's Avatar
Thanks. 3Gs is too much for me
lovin1stgens
09-25-2012 07:25 AM
Bubba J
02-25-2009 08:33 AM
starflite3
01-19-2009 06:31 PM
R-O-B
13
03-16-2003 11:59 PM
AFMSgt
01-26-2003 08:27 PM
Quick Reply: 5spd to 6spd swap
