5sp to 6sp conversion
Old 10-30-2005, 09:30 AM
triplem383's Avatar
Has anyone come up with a way to hook up speedo on 97 3500, if I convert to 6sp manuel?
Old 10-30-2005, 09:44 AM
signature600's Avatar
Yep...add a transfer case!! That's what I did!!
Chris
Old 10-30-2005, 09:53 AM
triplem383's Avatar
Looking at your sig, you added 4wd transfer case to 2wd duelly? New Dodge trucks with 6sp, speedo runs off toner ring in rearend. With transfer case hookup, is speedo accurate? My truck spends 95% of its life under 46ft trailer, and must have speedo, because of amount and variety I travel.
Old 10-30-2005, 10:03 AM
From 98 and down (I think) the 4x4's used a pickup gear in the t-case...just like the 2wd's used in the extension housing!! So yes, it's as accurate as it was before!!
I got my Tranny from Blumenthal MFG...1-3/8" input shaft, NV5600.
I got the NV241DLD t-case from Transfer Case Express. I was going to go with a NV241DHD (a little heavier, and has PTO Provision) but he didn't have the parts to build on with the speedo gear for a NV5600, and I needed the truck, so...
HTH, any more questions?
Chris
Old 10-30-2005, 10:17 AM
triplem383's Avatar
What are drive shaft issues, etc?
Old 10-30-2005, 10:34 AM
Shorten the rear about 18" I think, and you'll need a new slip yoke for the output of the t-case!!
Chris
Old 10-30-2005, 10:40 AM
triplem383's Avatar
Thanks for the info.
Old 10-30-2005, 11:45 AM
It is an expensive item just to keep the speedo, but the six speed is worth it!! I also think I'll use the low range of the t-case pulling trailers around farmers barnlots, and pulling some of the heavy implements we do as well. Don't know yet, haven't got the t-case shifter installed yet, but I'm working on it
Chris
Old 10-30-2005, 09:56 PM
12vstrokethis's Avatar
what about a gps system to see how fast you are going
Old 10-31-2005, 09:10 AM
Got one of those too, but the old men who occasionally drive my truck have NO idea what that is!!
There are probably other ways you could do it, but I think there are advantage to the t-case...especially if you tow a lot. Jockeying trailers around in tight spaces would be easier with a slower gear, and climing hills into barnlots with heavy loads will be easier too!
Chris
fade94
04-15-2010 09:23 PM
rockittboy
12-29-2005 11:46 AM
Captain57
12-01-2003 10:09 PM
shrtmntdiesel
10-25-2003 11:29 PM
Quick Reply: 5sp to 6sp conversion
