4x4 steering box mounting plate
Old 01-08-2010, 09:33 PM
MBolivar's Avatar
Why do we have it on the W trucks and not the D trucks? I am on my second cracked plate. I know they remove it to do the crossover setup. Is it a clearance issue that requires the use of that plate?
Old 01-08-2010, 10:55 PM
simplysmn's Avatar
they use it on the 4x truck's cause of the drag link If you go to crossover you can forget that plate plus have a better driving truck
Old 01-09-2010, 09:43 AM
MBolivar's Avatar
Would a dropped pitman arm allow clearance for the draglink to eliminate the plate? I don't understand why I'm on my second plate when I never take the truck off road and I'm running stock 235/85-16 tires.
Old 01-09-2010, 12:34 PM
Montana2x2's Avatar
I think I read that you need a lift to use crossover steering. How much of a lift I do not remember.
Old 01-09-2010, 04:54 PM
Rick 12v CTD's Avatar
I've heard you need 4" or more of lift to get the crossover steering to work.
Oh how I wish I had highsteer crossover steering.
Old 01-09-2010, 05:02 PM
simplysmn's Avatar
Yes I believe you need at least 4 in . of lift to run crossover steering but it's worth Every Penny you spend on it makes the truck alot more fun to drive .
Old 01-09-2010, 06:03 PM
Bogie's Avatar
Are you using the redesigned steering box mount ? The New box bracket PN # 52037876 is slightly thicker then the original. As for the reinforcement bracket is being reproduced by Dodge Connection @ $48.00
For a How To on boxing the frame at the box see this link to Ramcharger Central
Crossover on a non lifted truck is hit or miss and will require a fair bit of mods to get it to work. The major issue is the engine cross member the drag link could be bent for some clearance but it would take a lot.
Old 01-09-2010, 11:42 PM
MBolivar's Avatar
Bogie, thanks for that info.
james1
01-26-2019 08:12 PM
I8SMK4U
06-13-2013 12:13 PM
V.R.Wheeler
08-04-2007 01:00 PM
serious
03-15-2006 04:26 PM
timb
12-17-2005 10:20 AM
Quick Reply: 4x4 steering box mounting plate
