4x4 dash light?
Old 01-23-2009, 08:01 AM
Joe Diesel's Avatar
4x4 dash light?
my 4x4 dash light doesnt go on when i engauge it (4x4 does work) i checked the lights via mopar1973man instructions of holding the trip button and setting the key to the "on" postion and it doesnt work. is there a fuse or sensor i can check and/or what bulb does it use?? thx boyz
Old 01-23-2009, 10:00 AM
infidel's Avatar
Sounds like a burned out bulb
Old 01-23-2009, 07:11 PM
sheriffav8r's Avatar
The light doesn't work with the normal testing. It only turns on if the actuator is pressed from the CAD on the axle. I doubt the light is burned out since it is an LED. You can't replace the light, but have to change out the whole panel. Take the actuator cover off, remove the vacuum motor and push the axle sleeve over to see if it works. Does your 4x4 engage (jumping going around corners on pavement)?
Old 01-24-2009, 02:20 PM
infidel's Avatar
I've replaced the bulb before on the 12 valves, it's not an led on the older ones at least.
Old 01-24-2009, 03:36 PM
TIMMY22's Avatar
There are 2 black wires on a plug that connect to your CAD on the front axle. Make sure they are intact and put some dielectric grease on the plug contacts.
You can always pull you're transfer case in gear, then take a short piece of wire and jump the two on the plug. If the light comes on, it's the ball switch on the cad.
Old 01-24-2009, 04:07 PM
Joe Diesel's Avatar
i have a vibration coming from the front axle when 4x4 is engage which i've never figured out what it is, and ya it does jump when doing a U-turn on pavement.
thx i will try this as soon as it warms up a bit its been -22C or -8F for awhile.
Old 01-24-2009, 05:26 PM
blackimpala's Avatar
Down on your CAD disconnect the electrical connector should be a two wire connector, put a jumper from one wire to the other, w/key on. If the light comes on the switch is bad or not moving enough. You could also check to see if you have power on one of the wires.
Floyd
Old 01-25-2009, 07:56 PM
Yeah, sounds like a bad 4WD switch. You can actually unscrew the switch and push the button in and the light should come on....
NoSparkplugs
17
05-17-2009 10:36 PM
barngal6
01-28-2008 08:04 PM
V.R.Wheeler
08-04-2007 01:00 PM
Mule Skinner
12-29-2003 09:52 AM
Quick Reply: 4x4 dash light?
