4x4 conversion
Old Dec 5, 2006 | 06:56 PM
loch's Avatar
4x4 conversion
Well in case the word hasnt gotten around I have recently found that you can not drive a dually 2wd into Lake Tawakoni with good results. So my question is, whats involved in converting mine to a 4x4 ?
Old Dec 5, 2006 | 07:15 PM
loco one's Avatar
i DID IT !!
WOULDi DO IT AGAIN no !! I am glad I did it ! I have a ausom truck now !!IF you look at the tread on this board that saids ( favorite color truck pics ) the very first truck that you see (clud cab, 10inch lift with big tires ) was a 2 wheel drive at one time !< not my truck ! but after seeing it < I decieded to build mine !
2wd and 4wd have the same frame ! but you need to change the engine cross frame ! need one from a 4x4 frame ,also you need the power steering fram bracket from a 4x4 I found a 92 gas 3/4 ton 4x4 at the pick & pull < I got all the stuff ,( brake lines, spring frame mounts, xcase cross member, & all the steering stuff ! ) If you do not have all the parts first !! I would not do it !! you need a donner truck < all my pick &pull parts cost $200 cheap ! my 2 cents !
Old Dec 5, 2006 | 07:27 PM
DODGE 92's Avatar
4x4
hey loch sup i no your the man for the job youll love your truck even more if you do it
Old Dec 5, 2006 | 09:39 PM
loch's Avatar
uhm anyone got a 4x4 donor layin around ?
I'm thinking that be the best path, does front end need to be from ctd or it the same on gassers ?
Old Dec 5, 2006 | 10:06 PM
loco one's Avatar
need a dana 60
gassers have a dana 44 front you need a dana 60 front axle ! about $1500
after you change gears .drw,to srw , etc ! cost me about $3500 to change over 2x2 to 4x4 ! see my sig
Old Dec 5, 2006 | 11:18 PM
loch's Avatar
change from a dually ? uhm that aint happening
Old Dec 6, 2006 | 06:26 AM
G1625S's Avatar
The D60 will be the biggest single expense, but after that, you better have a list and check it twice since all the little things can add up You don't NEED the steering bracket--just convert to crossover steering, which eliminates that weak link. I think it'd be a great project
Old Dec 6, 2006 | 08:58 AM
Mcmopar's Avatar
That is one beautiful truck!!
There are a lot of gassers running around with the D-60, it just depends on how they were optioned.
Canam
Apr 12, 2009 10:37 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
Micaiahfied
Oct 12, 2005 04:00 PM
deere nut
Mar 6, 2004 02:21 PM
