4th gear low range or 2nd gear hi range?
Old 06-21-2010, 11:36 AM
OrangeBlackHD's Avatar
i cant decide which gear to pull sled in...i pulled last weekend in 3rd gear low range and got 280ft....but the video didnt show much wheel speed at all. I have 285/75/16s and 3.54 gears. Just curious if i could drop down to about a 30 to 31 inch tire and be able to pull in 4th low
Old 06-21-2010, 12:09 PM
graphitecumnz's Avatar
how much horsepower do you have
Old 06-21-2010, 01:03 PM
not sure....got a 4gsk full cut dvs, ddp 140s, 16.5 timing, ?# fuel plate, 215 pump (97).
Old 06-21-2010, 01:04 PM
and wh1c turbo w/hybrid kit...60mm compressor wheel
Old 06-21-2010, 05:37 PM
I'm not really seeing enough power to try 4th on the low side... what RPM did you hold on 3rd low side?
Old 06-21-2010, 07:52 PM
J Lent's Avatar
I just snuffed mine 3 weeks back attempting 4th low on a heavy sled. I'm at 611hp+. I run 2nd high usually.
Old 06-21-2010, 08:21 PM
held right at 3400 down the track. the gov springs need about 2-3 clicks more a piece i think. just did the math and if i run a 31 in. tire and use 2nd in high range ill be runnin right at 28 mph down the track so thats prob the route ill go.
Old 06-22-2010, 07:11 PM
I'm going to say your best bet is going to be 2nd on the high side. I wouldn't go messing with your tires just yet unless you have a mounted set handy or feel like dumping some cash... your 3.55's aren't really ideal for sled pulling if you were to get serious about it anyhow.
FYI, we run 4th low side on a 900+rwhp sled truck...
Billwie
10-04-2008 03:07 PM
Firstgenfanatic
04-10-2008 12:24 PM
Mark Hodowanec
03-19-2007 05:55 PM
trout74
08-29-2005 06:25 PM
Quick Reply: 4th gear low range or 2nd gear hi range?
